Disables routing for one or all interfaces. If no argument is provided, disables routing for all interfaces on the current VR or VRF.
| vlan_name | Specifies an IPv6 configured VLAN. |
| vlan_list | Specifies a VLAN list of IDs. |
| tunnel_name | Specifies an IPv6 tunnel. |
| vr_name | Specifies a VR or VRF. |
Disabled.
When new IPv6 interfaces are added, IPv6 forwarding is disabled by default.
The following example disables forwarding of IPv6 traffic for a VLAN "accounting":
disable ipforwarding ipv6 vlan accounting
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
